help! sharpening/regrind
TITAN1833
Dark! Dank! Murky! England.
Hello can anyone help? it is my neck knife/box opener :thinking:
I purchased this sometime ago,and I need help!
I have tried to re-sharpen,well it turned out I'm no good at it.Can someone help,it is 440 SS 3mm thick,I would like it to look like new but only better.
I would like it to be double edged,tanto style blade.I think there is enough steel for this.
anyone! help please?
Knives that have serrated edges typically require special grinding equipment. Stainless steel blades are best done with diamond-coated stones.
For non-serrated edges, a relatively inexpensive sharpening kit is made by a company called Lansky. It consists of a jig that will hold the blade and then allows you to select one of 3 sharpening angles 5/10/15 degrees (I believe). You won't be able to use the stones with the kit (they are for carbon steel blades), you will need to purchase the diamond stones separately. (not cheap). Attempting the sharpen stainless steel blades with non-diamond stones is a complete waste of time and usually results in making the edge duller by the time you are done.
You can also purchase a round diamond sharpener to sharpen the serrated portion of the blade. But it is done by hand and usually only successful if it is just "touching up" an edge. If you attempt this, read the instructions very carefully. Sharpening is not lengthwise along the edge, as it would be with a straight edge.
For dull edges, I would recommend sending the blade/knife in to the OEM for sharpening or replacement. Or find someone locally who knows what they are doing.
All in all:
Lansky kit: $45
Diamond hones (need at least medium and fine) $45 ea.
Diamond round (for serrated edge): $30
Unless you have a lot of knives, it's usually not cost-effective to get the setup.
Serrated edged knives look "cool" and have some nice qualities, but lately, I have gotten completely away from from because of the difficulty sharpening them.
I also have gone back to good RC60 carbon steel instead of stainless, a much better edge can be put on them.
I'll second mr. Krein. You will be happy.
I paid $50 for a somewhat major reprofile and sharpening of a mini griptilian. But that changed the knife from one that sat around to one I use regularly.
Email him...He'll probably call you shortly after. He's great to work with.
Thanks guys I'll shoot mr. Krein a email,it may work out cheaper to get him to do the work rather than buying a sharpening kit.To which I would have no clue using anyway,I would most likely sharpen away until the blade disappeared :whistle:
Spyderco has a ceramic v-type stick sharpener with triangle shaped stics to sharpen serrated blades. I use the V-type or "croc stick" type 99% of the time on regular knives and kitchen blades.
If your blade is flat on the back side you don't want to do anything with that side but remove any nicks or burrs. Do all the work on the front side bevel. With the V-sticks, you may have to hold the blade at an angle where that little bevel is flatter against the stick. Normal two sided bevel blades are held vertical to the table to give a tiny bevel on both sides. You then just glide the blade down each side on a stick in an attempt to shave the sticks.
Some grades of 440 require a lot of sharpening as they go dull quickly. A sharpening setup will pay for its self over time. I have a Gerber Gator and a couple of Spyderco's that I have never managed to dull and a Buck that gets dull by swinging it through the air. And they have cut up a few cardboard boxes that should have dulled them in short order. And yes I know the Spyderco's are AUS-8 not 440.
So you would like the top spline ground so it too has a cutting edge?
The beauty part about the job he did on my knife is that he brought the edge down to around .01 of an inch. I can cut works off of newsprint without cutting through the other side.
Best of all I can touch it up on the sharpmaker very easily.
Titan...I'd recomend picking up a cheapie little knife from walmart or somewhere as a practice knife. You'll be able to wreck it without while you learn to sharpen.
As far as a double edged tanto goes...if the top side is going to be sharp all the way to the tip, you're going to lose a ton of tip strength.
great idea I have just the host to practice on,my cooks knife I use in the kitchen at the moment I can't slice butter with it here's hoping fingers crossed :twothumbs
[edited]BTW if I'm successful I will post here,but don't hold your breath :whistle:
