kramer5150
I am not sure how this happened but for some reason I can not get my SF-A2 to twist-ON the incan lamp. This light is used but not abused, I've only dropped it once onto padded carpet, and I can't physically see anything wrong with the tailcap or body tube.
When I screw the tailcap all the way down, the incan does not turn on, and the momentary switch has not fully seated against the body tube. With the cap tightened down 100%, I can still depress the momentary button and manually activate the incan lamp.
I have used 99% isopropyl alcohol to clean the threads and the critical parts are free of gunk and debris. It is an intermittent problem, I can get it to work sometimes.
Hopefully its a simple fix:confused:
