Help with wiring a SOB board
tx101
London UK
Seems the Shoppe site will be down for the weekend :(
Can anyone tell me where to solder the wires on a SOB board
I am half way finishing a light and thats all I need to finish it.
Thanks in advance
Black: GND
Green: LED-
Red: LED+
For LED- and LED+, you can use either of the two holes that are next to each other. That is, for LED-, you can use either of the two holes near J5; for LED+, you can use either of the two holes near J6 and the two sense resistors.
What are you building? You can bring Vin via the center anode pad on the backside of the SOB (e.g., put down a solder blob and attach a spring, which would contact the top, positive nipple of a battery), or via the Vin hole of the SOB (the relatively large hole next to the ST1S03 IC).
Many thanks Justin :twothumbs
I am building a Cree R2 Maglite C, running 2 x 18650 plus an aspherical
lens with a Nanomiser SS bezel
