CompFreak247
- Joined
- Oct 3, 2007
- Messages
- 20
This might not be bright enough, but a very tough light that can be had for cheap and has a long battery life is the Inova X5. I recently got one New In Package (With the newer LED's, too) for $25 with shipping. Your local target store will have them for $35. The batteries are CR123s, which are expensive at local stores but can be found for cheap online, and will give 6 hours of light before the drop to %50, and supposedly another 10+ hours beyond that of dimmer light. It is bright for the size and price, nearly indestructible, and is fairly floody with a good beam. However, it isn't very good for spotting at distances of 50+ feet, although it is visible up to about 100 feet in total darkness, so unless the 'coons come up close, it might be the wrong flashlight for you. Other then that, try a maglite - my dad has a cheap craftsman knockoff, and it seems to work fine. The adjustable head on a maglite is very handy - it allows you to switch from a wide flood to a narrow beam. If you really want to up the light output from a maglite, put a LED bulb in it (Seek the advice of older and more experienced CPF members if you want to try this.)
Hope this helps,
-CompFreak247 (Proud CPF Newbie!)
Hope this helps,
