High CRI (Warm white) 4 Sevens Preon 2 + Neutral White Comparison Review
UnknownVT
By the courtesy of 4Sevens I have on loan the new High CRI (warm white) Preon 2- as well as the current limited run Neutral White to look at.
Size -
the 4Sevens Preon 2 has been around a while now the size and appearance do not vary - they all look like the long black one (marked as the 1st gen Warm White)
I specifically asked for a couple of different colored Preon 1 bodies to show that one can play "lego" with the Preons - to configure them as Preon 1's with clickies. Normal cool white Preons do come in different colors as well - as shown in the blue colored Cool white Preon 2 - but that has the standard supplied plain end cap for the Preon 1 - which makes the light a twisty........
So this shows the Preon is a very versatile system light.
How do the High CRI, the current Neutral White compare with the standard Cool White?
This may be the best way -
do a show & tell....
Although the heads are are mostly black
there is a difference between the warm whites and the cool or neutral whites
in the emitter/reflector:
Enough of the introduction -
rubber meeting road -
High CRI (Warm) Preon 2 vs Cool White (1st gen) Max, NiMH
The High CRI being a Warm White shows distinctly as yellow/orange in comparison to the Cool White.
High CRI (Warm) Vs 1st Gen Warm White Max, NiMH
doesn't show so well in photos - but the High CRI seems to show paler yellow going toward pale green - the 1st gen Warm White seems pink/browner to my eyes
High CRI (Warm) vs. current gen Neutral White - Max, NiMH
what surprised me was how UNyellow the Neutral white was - in fact when I first got the Neutral white I thought 4Sevens had mistakenly sent me Cool White!!
This probably means that 4Sevens got a higher color temp bin of Neutral White - perhaps not the fabled 3A (I wish) - but it seems closer to the 4 bin rather than the previous 5A3 or 5B3s.......
Neutral White vs. 1st gen Cool White, Max, NiMH
this comparison illustrates how cool these current Neutral Whites are, if I were guessing - they are possibly 4A or B's?
I am really liking these as they do almost give a "neutral" color at night when yellow tungsten (2700deg K) is prevalent.
So how does the High CRI work out?
To be very honest I found it very, very difficult to tell -
especially when I compare the new High CRI and the 1st gen Warm White.
Probably the best way is to just present the photos I took of homemade Macbeth color chart -
and place them next to each other
(I think CPF is arranged in such a way that I can no longer see my beamshots laid out next to each other horizonatlly - at least on my monitor - hopefully some with higher resolution and/or wider monitors can see that the comparison beamshots are laid out in pairs?)
I can see the desirability of having High CRI
(I believe that is one of the reasons for the slower acceptance of LEDs in general lighting - cost being the overriding one for now)
However on this look-see - subjectively I was very pleasantly surprised by this variant of the Neutral White - which looks a lot cooler/whiter than the two previous limited runs of 4Sevens Neutral Whites - I managed to mislaid my Preon Neutral white -
but I do have both limited runs of the Quark AA variants that I can do comparison beamshots to the current Neutral White - if there is any interest.
That's been my observation as well. The CRI is higher because of the boost in Cyan output. The standard warm emitter always looked very pink because of it's high Red output. The higher Cyan in the HCRI counteracts this and the colour is much more balanced, in my eyes at least.
Thanks for the corroboration.
That sounds very logical.
However another possibility is the actual binning -
and if we followed your logic about the difference in appearance - then choosing a bin that tends more toward green and blue (ie: cyan) would then result in higher CRI - this unfortunately is not the case.
I also think this way, and have coveted the bin 3A which is about 5000+deg K - but I have been told this bin although in Cree's books as Cool, Outdoor and Neutral whites - 3As do not seem available -
As a bin that is cooler than warm or neutral should have more blue
and being warmer than cool white ought to have more reds/yellows -
giving a very good compromise - thus possibly higher CRI - but this just not so -
most LEDs on the Planckian Locus have good approximation to the same color temperature lights -
but they have poorer CRI due to PEAKs in their spectrum -
so much so that there were proposals to measure the CRI for LEDs differently(!)
- the purported support for doing this is because LEDs seem to render colors better than their pure CRI would indicate.
Just to show the practical worth of CRI
and how it could be misunderstood and
placing too much importance upon -
Everyone knows how difficult to it is to read yellow print on white
and distinguishing navy from black
under tungsten light -
Yet the standard commonplace tungsten light bulb has a CRI =100 ie: PERFECT!
Thank you for the review. I definitely feel some comfort with the two Preon 2 High CRI models I have ordered. The chart showed richer colours under High CRI to my eye. Looking forward to using them.
What's the difference in output between WW 1st gen. and new Hi CRI ?
WW 1st gen. was too dim and yellowish for me compared to CW.
In Mini CR2 on Max. it was closer to Mid on CW.
So is there any OTF lumens improvement in Hi CRI ?
Great review. You wouldn't happen to have any incandescents lying around to do a side-by-side with the HCRI would you? (just for tint comparison purposes)
Also when you mention the HCRI leans towards a pale green, how green is it?
Here are some pictures I took for cct/tint/color rendering comparison purposes. One of my contestants is my incan Surefire M3 with HO bulb, one of the others is my Ti Quark, modded with a HCRI (90+) XP-G.
http://www.candlepowerforums.com/vb/showthread.php?321243-CRI-tint&p=3736435&viewfull=1#post3736435
And here's a 7 light CCT/CRI comparison that I did a while ago that includes an incan and a 1A,5A and 7A bin Cree, 7A3 HCRI Cree and a 5700K SST-50
And yes, LED's have a very "peaky" output. High CRI emitters tend to have a flatter output, hence a wider spectral output, hence Higher CRI. CRI is not, however, directly related to CCT, which explains:
So the warm emitter puts out a lot more red than a cool white emitter cchanging the CCT (but not necessarily the CRI) but there's a big trough in the output at the cyan wavelength, pushing the colour balance towards brown/pink. The flatter output of the HCRI emitter fills in the trough at that wavelength, pushing the colour balance back to a more neutral place (but that would look green if your eyes were used to the output of the standard WW emitter). This does not affect CCT (believe me when I say I don't understand why, but I know that it is true, after reading posts of much much smarter members here)
I'm struggling to see the CRI difference myself. It might just be how my laptops display represents the color and it will be more obvious when I have one in hand.
The prior warm run had two tints, one was more rosy than the other.
i would love to see the color chart with sunlight AND with the 2nd run XPG (not the most recent NW run) of quark neutrals. the most recent NW run was an ugly green cool white; it was not neutral at all in my opinion.
i was considering getting a high cri quark, but i'm really hesitant at the moment.
thanks for the review!! 🙂
I have three High CRI lights in the mail that should arrive today. Quark 123, Mini AA, and Preon 2. I also have on hand a Mini AA and Mini 123 with the XP-E Q3 5A or 5A3 tints. I will see if I can take accurate beamshots tonight, but I don't know if my iPhone 4 will accurately represent. I have the most recent run of 4S neutrals as well. I'll see if I can add a comparison with the HCRI and my 3D Maglite.
Thanks for the review, looking at the pic. I only notice a difference in the white border of the two. I traded my old warm white quark for a nuetral XML head, then bought a hi cri 123. This way I don't have such an overlap.
How thick is the preon two though, decent pen light replacement?
I read some where in the led forum that the old warm white are around 80 cri. And that the new hi cri quarks have three bins they use so you may end up with better than 85 cri.
Nice comparison picture there with the color palettes. Would you mind doing it with midday sunlight?
Not at all...
in fact I meant to post this - but there was just too much hurry on my part - thanks for prompting me, and I'll edit to add this in the opening post:
While I'm at it - a real GE "soft white" 60watt incandescent bulb:
Streamlight Scorpion incandescent
That's another good point I forgot. The gamut that your computer screen is capable of displaying is quite small, and unless you've had it properly calibrated, you can't trust its output. The ONLY way to get a proper comparison is to see it in person.
Nice review and great photos! I don't know...call me silly, but I still prefer the Neutral over the Warm or High CRI...
Not at all. We buy the lights and use those that meet our personal preferences. 🙂
Not at all...in fact I meant to post this - but there was just too much hurry on my part - thanks for prompting me, and I'll edit to add this in the opening post:
Thanks!
I see some differences in colors but I don't know if it's cuz of my screen. Which one do you think looks closest to sunlight?
This is pretty subjective -
the cool white ought to be closest to daylight D65 - which is color temperature of 6500K - that is supposed to be noon daylight with clear blue skies - but I find it slightly blueish
Sunlight is supposed to be 5500K ("D55" if it exists - the closest standard is D50 @ 5000K)
the current batch of Neutral Whites seem warmer than D50 (I have CRI90 D50 fluorescent "Sunlight" tube to compare) - but the current Neutrals seem close enough that I actually on first sighting thought 4Sevens had sent me Cool White instead -
so in this batch (and I freely admit my bias) the current Neutral White seems closest to D50.
the Cool white definitely shows as too blue and the High CRI (warm) is definitely too amber/yellow.
If I have some time I'll take photos of these lights on white paper that's illuminated with D50 lighting.
In the meantime read these - please -
Most of us "see" common tungsten lighting as "white"
(even though a lot do know it is very yellow/amber when compared to sunlight/daylight).
There is a very good reason for this,
as our eyes/brain adjusts for what we perceive as "white" for different light levels,
please see:
Kruithof curve
- Wikipedia, the free encyclopedia
The Color of White
