NewBie
*Retired*
andrewwynn said:can fit 9x 17500 in a 3D... you can fit 12 14500 in a 3D.. now that's a very interesting solution.. See.. with my LDO.. putting 1185 into a 14.4V solution is horribly inefficient.. oddly enough even so it's just as efficient overall as the 1154 which runs at 14V but is far less efficient in lumen/watt..
That would be a most excellent use of the switching driver.
What you can fit into that host is 12xR123 for 14.4V... you could also put in 12X NiMH... also for 14.4V.. at 35W and say 95% efficiency.. means you need.. only 2.55A from the cells vs 3.35.. that is not insignificant a difference.. very interesting though there.
In addition.. it would be nice for the primary based solutions like running the mag 85 from 12x 123 primaries.. which would be 12V no-load but 10V under load.
I will definitely be exploring 'version two' of the hotdriver in the form of a switcher.
-awr
Speaking of the 12 R123 cell configuration, and your 12.5V bulb at 2.05A, do you realize you'd only need to pull less than 0.6A out of the cells? There would be a tremendous efficiency increase in the batteries alone, with a switcher vs. a linear.
Hopefully I can get you interested into researching it more for your products. There are some really nice improvements you can make with a switcher in those configurations...
