Well, it does have a Lumens Factory tailcap so I guess the "Lego" designation fits;
I received the Hound Dog XPL head yesterday and configured the light as planned;
The XPL is rated at 950 lumens and 44,000 candela. In visual comparison with my other lights, these specs appear to be correct. Compared to the M91T, the beam hot spot is not as wide but much brighter, and a little less light in the spill.
At about 70 lumens / 3,200 cd, the low setting is very useful: it's more than enough to walk the dogs or to take a stroll down the street after dark. In the photo the Malkoff markings on the body and head are aligned, this being a perfect reference for the low setting. It only takes about 1/8 turn to get high. I think I'll add a tritium tube on the tailcap to align with those markings to reference my preferred switch sensitivity.
The O-rings on the body serve as grip rings when holding the light with an ice pick grip, preventing the light from sliding forward in the hand when activating the switch with the thumb. At least for me they help immensely.
At seven inches long and 10.6 ounces, this is not what I would consider an EDC light. But it can ride in a cargo pants or coat pocket, so if I know that a light will be needed it can be carried on those occasions without much fuss. It fits in the right-front zippered pocket of my relaxed-fit Duluth Foreman's Pant without issue.
For its size, weight and performance, a good combination IMO.
- MD3 body
- XPL head
- LF UM00 Tritium Slotted Momentary Tailcap
- LF Z26 lanyard ring and finger loop
- Powered with a pair of NCR 18500A 2000 mAh flat top cells
- Run time on high - approx. one hour; run time on low - approx. 12 hours
- AOL = 6-13/16" (7" with switch boot projection)
- Weight with cells = 10.6 ounces
