Can someone tell me if the Quark 123/AA holster will fit well on the E03? Any other suggestion of a holster for this light? Thanks!
A friend has been using the E03 for the last two months - heavy use, and the switch has become soft and unreliable for changing modes - they may not change, or the light my not fire at all. Anyone else experienced similar unreliable modes?
I got a Blue/Purple XP-G from Jason a week or two ago, based on recommendations in this thread.
I have not been disappointed, it is a very nice AA light. Gotta look into getting some 5/8 in GITD O rings now...
...Although hard to say more without directly testing both, I would recommend you choose between the XM-L and XP-G versions on the basis on the beam pattern (i.e. flood vs throw, respectively).
I also saw the same thing with mine but it will come on sometimes. If I unscrewed the tail cap and removed the battery and put it back in it would work for a little while. Sometimes the modes will change a couple times and sometimes the light will come on in different modes. I thought something was wrong with the light but a new battery worked fine. It is very strange behavior and I have no idea if it is normal.Hi, i'm from Italy and i have buy a Xeno E03 XM-L and i have noticed something strange. If i use NiMh battery, when the voltage drops below 1,2v (low battery) the E03 would not light ON. Is it normal? Can someone do a test?
If I put the same battery in another flashlight, it works.
