How Do You Protect a P60 Drop-in?
popcornpicker
A 35mm film case looks like it would work, but since everybody is digital, I'm not sure where to get them.
I bought a host but I want to carry different drop-ins with me just to try out the different attributes of each.
I don't want to send away because it will be a 4th of July thing, but I don't want them to get crushed under camping gear either.
Thanks.
Not everyone is digital. Ask at any local film processing place.
Would a waterproof match case work?
If you have multiple drop-ins, I'd take a look around the stores for a tackel box... You know, one of those small clear ones with the little adjustable compartments. That way they'll all be together and protected.
I don't want them banging around in a tackle box either.
Thanks for the suggestion but I'm trying to keep volume to a minimum also.
Another idea that might work would be a piece of PVC pipe and a couple caps. Depending on how many drop-ins you want it to hold, you could cut to the length you need and use pieces of foam, cardboard, bubble wrap, or whatever between each drop-in.
Get a small plastic tube of Mini M&Ms. There is a lip at the opening that holds the drop-in perfectly. The lid will close and the drop-in is held securely. I have shipped several P60Ls in these and never had a problem. I aklso use them to hold spare 18650 batteries.
If you have a Costco nearby, stop by the photo processing area. They usually have a few lying around and will be more than willing to give you a few. I still shoot B&W film and have a few lying around and they do fit, though a bit loosely.
Many prescription pill bottles, with a little foam lining, work very well. You can get an empty, unmarked bottle from most pharmacies if you ask nicely and tell them what you want it for.
I'd been using an old vacume attachment (a slightly conical tube with an interior rim that perfectly seats the reflector 2mm inside the tube, by all apperances it is custom made). And of course pvc pipe is great (i tape up one end, then fold in a the drop-in with a peice of bubble wrap.
some awesome ideas here too. I'm gonna try the rx bottle when I get home, phase out my pvc pipe p60 holders if it works.
Best,
L
get more P60 hosts... :naughty: kidding.
i think pipes cut to length with end caps may work, just need to add some foam to prevent clatter.
This is the kind of thing ebay does really well. These even have side clips and o-rings:
damn if i had the time I would post a picture with more color options than this...
Kinder suprise eggs (and other local firms) containers....
And There is a color coding system for me...
blue for 6V
black for 9V
green for 3.6V
red for 12+V
solid colors are LED - half transparent is Xenon
and I have also PINK ones
