You can create an own LED light structure for 12V DC (as for Yachts or car / camping / battery power supply)
The modules (4W and 5W ) are created with additional protection for overvoltage, reverse voltage also for some spike up to 500V/10usec hits.
Several LED colors available.
Another advantage, is that the additional protection, permitting connection with very long wiring (up to 30 meters) can be used for several parallel connected modules, this way, no problems with switching off/on of any lamp independently is occurring.
Modules are made on metal core PCBs, insulated at 2000 v from the base, and are easy to be mounted on cheap heat-sink or directly cooled from the metal body of the lamps.
Modules are with 4 LEDs for 12V DC application (from 8.5V to 16V DC with reverse connection protection) power 5W and with 3 LED for 12 V AC with build-in rectifier and DC filter - power 4W.
44mm and 48 mm diameter.
