How to go 2x18650
BionicSniper
Des Moines, Iowa
Ok i just got my M3T. I know i can use the 17's right now but to get the 18650 rechargables can i just put an a19 cell extender on there or will i have to get the leef c-m body?
M4 bodies can be bored cheaply if you have one. If you don't, then the Leef body is the best option (through Lighthound).
I have a M3 running 2x17500. I've heard that boring these for 18500 cells will possibly make the walls too thin.
My M4 is out for boring and a new head w/ Milky, so I can't compare the M3 and M4 bodies at this time.
2 Li ions don't provide enough juice for the stock M4 lamps.
You can use the M3T bulbs if you're willing to put up with the drop in output.
I had Highorder bore out my M3 and A19 to fit 2x18650-awesome setup with HOLA. Whiter than my M4 225 lumen bulb
Pete - I'm just waiting for the bits to do this myself with a leaf body, what sort of bulb time have you had?
