kelmo
Here is my mini review. It says BugOutGear 3W Cree on it. It does not say Premium. It is a hefty unit, all aluminium and brass. The bottom of the module has what appears to be naked circuits surrounding the solder blob that makes contact with the battery. But they are low profile and should not come into contact with the battery in the event of a bezel down impact. There is no spring on the module. When I first tried installing it in my 6P it would not fit. It took some gentle yet firm twisting to get it to mate into the battery tube. Removing it also requires a considerable amount of force and finesse. This thing fits like a glove. There is no bezel gap. Very nice. Upon 1st activation it would not work. I had to tap the bezel. After several removals and installs I seem to have a good solid circuit. The momentary switch and the lock out function are not effected in any way.
Now the good stuff. Man this suckers is bright! It easily competes with my 9P w/P90. The hotstpot is an intense white. The tint is comparable with my HDS B42 XRGT. There is plenty of sidespill. The reflector does a good job of deliverying a smooth artifact free cone of light. Of course it is daylight and I'm doing a white hallway test. I put a half depleted pair of cells and the intensity apprears unchanged as eyeballed against a new pair of cells.
I can't wait for darkness! Now if I get 90+ minutes of regulated runtime I will be a very happy camper. A 6P with 9P performace and more/regulated runtime. WOW!!! And I can reverse it out in the field if I fry the emitter (provided I have a SC1 with me)!
kelmo
kelmo
