I moded a incandescent bulb to Seoul ..[ Not Luxeon ]
Re: I moded a incandescent bulb to Luxeon ..
Good work :twothumbs , i must get round to making a few of them like that for a few of my older lights.
well done!
There's only a few individuals on the forum that can install an entire driver circuit in a PR can, apparently your one of them:thumbsup:
Which schematic did you use?
Any build photos?
well done!
Any build photos?
I could do it with a resistor , but this is Direct drive ..
Its for my old 1970's 3D flashlight .
I haven't tried it with fresh batts , what I generally do is run my 3Dmag till it gets weak , then swap the batts into the 70's tin wonder , it had a 1W LED bulb in it that put out with used batts , so I figure I would try a left over Luxeon LED , if it fried , no loss , but it works real well . An incandescent bulb is dull yellow and you can hardly see anything with it in the dark , this thing puts out like an incandescent on fresh batts , its more than twice as bright on dead batts than the 1W LED bulb I got .
D's being expensive , I want to suck every mA out of them before discarding . + I was thinking of getting some Nicads 3x1.2v = 3.6v [ so should be fine for DD ]
Is that a Rayovac Sportsman?
No . its a no name made in Taiwan 1970's Tin 3D .
I actually purchased it in the 70's New [ My first flashlight ] , and have kept it for some 35 years . Im still thinking of a way to do a high performance [ R2 ] mod , that wont spoil the light .
Hmmm , perhaps Luxeon K2 TFFC ? Bulb mod ? But the heat ? How to get rid of the heat .
I should have taken more pictures : The mod is pure genius in simplicity .
Whether it can handle 3 fresh D cells ?? 2 D's would probably be ok . as it would be under driven , but fresh cells and 4.5v , I just wonder if it could handle the heat . Oh well , works well with depleted cells , which is what I wanted .
Is there supposed to be a link or a picture or something? :thinking:
3rd pic shows a Seoul
:thinking:
so why "Luxeon" in title?
(would not make much sense, to use Luxes now)
:thinking:
Came from flashlight claiming Luxeon LED ...
Whoa - Ok ... All my older lights were supposedly Luxeon , and I think your right ... After a closer looksee , it looks seoul !
:awman:
I definitly have to try this as I have an old 2C Maglite liying around here and don't know what to do with it.
rayman
Here's someone who has modded lots of old lights.
Naa wont turn blue ...
I actually soldered a bolt to the bottom of the LED , then fed the bolt through the bulb and used a rubber washer and a nut to hold in place + epoxy glue .
The bolt is the heatsink + the positives terminal , negative is to the bulb body .
I then used a hand held motor tool to grind the nut and bolt at the bottom to shape .
Extremely simple in design , and easy to execute .
