I want to build a dirt bike LED headlight, advice please.
michaelmcgo
I Plan on building a headlight assembly with brightness equivalent to a 50W automotive bulb. The bike has a 12v 4A battery. I was thinking of a cluster of Luxeon, Seoul, or Crees, how many can I run off a battery of this size. I work in a CNC shop and can design/cut just about any style of aluminum housing. I would like to pack the LEDs as close as possible, and can make my own reflector out of the aluminum housing. I will need some advice as far as what kind of electronics I should put into it, such as resistors to get the input electricity where I want it. Thank you.
For that amount of output, I think 7 Cree XR-E LEDs(I'd recommend the Q5 bin) or Seoul P4 U-bin LEDs should be enough.
Drivers, I think three of these should work.
Wiring up the above drop-ins would be a simpler option(not sure about size though).
Heres a bicycle mod to see whats been done with these drop-ins
Just add a good lens to keep the mud out
Theres an index in the Transportation Lighting sub-forum
If you can get the drivers Gunner12 recommends (they've been sold out for weeks)
Make a custom light bar or 2 like this http://bikeled.org/
It's been years since I've had an electronics class, and don't remember a thing! Can I wire lets say 3 of these (or any 3.7v LED) in series on a 12v input? Should I wire up 4 instead and undervolt them a bit? Why should I use a driver, or is direct drive okay? what do I get by using a driver (the battery is being continuously charged)?
Three will overdrive the LED(not including voltage spikes and stuff, which could destroy the LED) and 4 won't have enough output.
A driver would ensure a constant current and constant output.
