There are lights that need for sure a cell with PCB, mostly 14500 lights that run with NiMh cells as well, they cut off at 0,9V and run with a buck-boost driver.
The Jetbeam Jet-1 MK is one it runs with lithium cell brighter but it would depleet the cell below 2.5V.
The PCB triggers and suddenly you have no light.
Other lights warn you before they shut down.
Other lights get dim as the cell voltage gets lower than the LED voltage at max current.
Even if the lights driver has a parasitic drain plus a voltage that allows only sub moonlight it takes many hours to a couple days to get below 2.5V and at that point you have no useful light output at all, so the cell gets only depleeted if the light is turned on unnoticed.
Then there are lights that simply cut off all parasitic drain from driver and LED as they detect too low cell voltage as you run it that low or turn the light on with depleeted cell, using a linear driver and regulate the LED down the more the cell voltage drops.
The light also may indicate low cell voltage by fkickering before it shuts down.
good PCB LG 18650MJ1, Sanyo 18650GA or Samsung 18650-35E cells will get you good performance.
The voltage drop on a 8A PCB is about 70-100mV at 5A
