IM SO CONFUSED
aaron_cg
I need to figure out how long these batteries will last with this bulb. I have a race this Saturday.
Here is a link to the battery info: http://data.energizer.com/pdfs/123_ap.pdf
And Here is the info on the bulb Ill be using.
Radio-Shack
Rated Voltage- 6.0V
Rated Current- 650mA
Lamp Type- KPR112
Brightness- 5.46MSCP
Thanks for any info you can provide.
The cell is 3v with a capacity of 1500 mAh (to 2.0 volts).
Your globe is 6v with a current of 650mA.
So you want to work out the power used by the globe first off.
Thats: 6Volt * .650Amp = 3.9Watts
The cell in watt hours has: 3volts * 1.5Amp Hour = 4.5Wh.
So in short, a rough estimation would be around an hour or so with more or less full brightness then it will quickly get dimmer for the next 30min or so to a point where its no longer usable.
Hope thats some help.
Edit: Just out of interest, what are you racing and whats the light your using?
to Aaron --
Does yer' light use just 1 battery at a time ?
Or 2 cells at once ?
Oh, by the way . . . .
:welcome:
_
to Aaron --
...or even three cells at once? The battery produces about 2.5 V under a decent load, so two will be 5 V. With a 6 V bulb it won't be all that bright. On the other hand three will be 7.5 V. The bulb is going to be over driven and shining like a star, if it doesn't go poof :poof: first.
On the whole I think we are more confused than Aaron. More information would be helpful.
My guess two batts , so your looking at run time ..
If the batt is true 1500mAh and current draw is true 650mAh
You will see over 2 hours , but depending on many things , light output will start to drop at a certain point . Easiest thing to do is load up and go for a ride to see when it becomes less than acceptable .
According to the Energizer data sheet the batt is closer to 1200 mAh, but yes, one hour up to two hours with decreasing brightness is most likely.
