Northern Lights
Improve the N30 with a 225 lumen LED area flashlight and an always on glowing LED spot light locator.
Quote: N30
Color - Light (close to Hunter) Green
35 watt HID 3200 lumen 4200K bulb driven at 30 watts.
70+ minutes run time from 13.2 Volt 3600 mAh NiMH pack
(I generally get 80+ minutes from a full charge, but we are only going to state 70+ in the manual)" Close Quote.
There are 11 cells in it; 47.52 watt hours.
The Amondotech N30 HID is a 35 watt bulb run at 30watt. It has a lamp accessory for near working conditions. The lamp is two parallels sets of a 3 and a 4 series 5mm 20mA LEDs run on appropriate resistors. And the cool thing is it is 26mm in diameter and the bezel just unscrews.
I dropped in this Cree R2 module for 225 lumens. Great area light, huh? R2 link
R2 drop in module runs on 3.7-18.0 Volts. The R2 is close to 4 watts so that is an estimated run time of 11-12 hours.
I learned about this link: ROP w/ constant glowing switch membrane
I stuck three 5mm LEDs in series and again in series with two parallel 100K ohm resistors in the back end which are on all the time, are there to locate the light in the dark. They draw 0.05 mAh together. That is 4.79 years of run time at 100% efficiency so let's be real and say 3.11years run time at 65% efficiency. It will be easy to find the light.
3 in series works out like this: Vf=3 (3.2)=9.6 at 20mAh.
In series with two parallel 100k Ohm resistors is 2/100K =1/Rtotal; Rtotal = 1/0.00002 = 50k ohms.
Ohms law: E/R=I
13.2volts – 9.6 volts = 3.6 volts
R= 50k ohms
I = (3.6/50000) = 0.000072 amps or .072 mili amps ~ round that to 0.1 mili amps
Now then;
3600 mAh divided by 0.1 mA is the run time in hours, 3600/.1=36000
36000/24 =1500 days; divide by 365 is 4.1 years, at 100% efficiency. Realistically, even at 65% efficiency the glowing LEDs do not drag down the performance or shelf life of a maintained light.
Easy way to do this is down load from one CPF member the LED PRO calculator:
LED PRO
It will figure your run times too at different efficiencies.
To put in the three LEDs the three were soldered onto a piece of copper wire and the parallel resistors put in series, two long leads were secured to it. Using a template the whole pattern was figured and drilled into the back end of the handle. The three LEDs were put into the outside of the handle and a piece of cardboard was secured in the middle with duct tape to hold the position. Using a pencil they were then set into the handle and pushed into position. Super glue holds them there. The black straps come off easy, the feet pull off and then the straps can be released to get to the switch and wiring. A ground wire goes to the area lamp and hot goes to one side of the switch; tap into these.
All I need now is to add a diffuser to it for closer high intensity work.
One night recently out in the boonies fishing, I dropped the light from the top of a Forest Service dumpster to the hard concrete. It was on when it took the fall and there I stood in darkness, considering how I would replace the bulb as I figured it was now deceased. No hot wire incan would have withstood that fall. I picked it up and slapped the back end… LOL!! The battery was loose and it seated with the slap and I had light again. What a good product, nice and rugged, small and realistically useable. The new area lamp module makes it available for all circumstances that I encounter for a light; it makes a good "boogey man repellent" night light with the constant glow too.
Thanks to
SALE: AmondoTech TITANIUM N30 HID search light 3200+ LM, rechargeable! $132.95 AC
Jtice and his posse
2xTrinity
mtbkndad
MattK
Ohms law: E/R=I
R= 50k ohms
Now then;
LED PRO
Thanks to
Jtice and his posse
2xTrinity
mtbkndad
MattK
