My car is Black.
then your all set, untill you go to arizona, in the middle of death valley, in the middle of the summer equinox, and leave it out at 10am, and come back at 4pm. 🙂
I live in california, and the temp inside the car can and does reach 140*+ when you dont do anything to prevent it.
i checked a few specs stuff (they all vary a lot) and the ni-mhy is about the same high, but lower operation temp for nimhy , is more like 0-32*f. operation means having to warm it up to use it.
nimhys are pretty well sealed, compared to li-ion, and handle pressures better. same with lithium primary, they are well sealed, and handle some pressure. the li-ion is supposed to stop operating when pressure rises in the cell.
so other than anything possibly popping or causing a fire, the li-ion is the most likly to "be damaged" when pressure occurs in it from heat. lithium and li-ion most likly to actually start a fire if they were highly over temperature..
