Is it worth spending extra for a charger?
kelsojack
I am unsure if i should spend exta on a Pila IBC or just get an AW charger.
Also which model of the AW charger is for 18650 cells and does it come with universal power plugs like the Pila?
The Pila IBC is worth every penny from what I have heard, I'm as broke as is gets so don't own one personally.
The WF-139 or a DSD will charge 18650s, but the WF-139 will overcharge if you leave them on too long, and the DSD lacks independent channel control, and charges painfully slow, and I have heard reports of it also potentially overcharging if left on way too long.
If I could trade in every dollar I've spent over the years on junk stuff, I'd replace it with a few essentials, one of those essentials would be a Pila IBC.
My recommendation based on experience, pay up front, get the good charger and a few good cells and a few good flashlights.
Everybody says the WF-139 overcharges but I'm not so sure that everybody that makes this claim even owns one. I have one that always cuts off charge at 4.16v I've put in protected and unprotected cells and never have i had an overcharge. I've left them in overnight and no over charging. It's a cheap charger and there will be some variance between units but some people seem to be positive that all units will be bad. I'm not telling you to get the cheap charger. You should probably get the more expensive charger. I was just trying to point out that with the wf-139 you might get a good one or you might not.
I have a WF-138 and a Pila IBC. The 138 sits in the drawer. It overcharges... can't trust it. The Pila works beautifully.
With flashlights and their accessories, its a false economy to always
go for the cheaper option.
I know that the thought processes go something like "I could get 2 or
3 of those for the price of that one"
However the "2 or 3 of those" may all be inferior quality and they may
also damage other components.
This is a general principle. I'd rather have one of something nice than
3 of something else that are clearly less well built and more likely to go wrong.
+1 on the Pila.
Just spend the money and get it over with.
Then, you'll never have to think about the extra few dollars ever again, but you'll be using a great charger for a very, very, very long time.
Do PILA have an outlet or distributor in the UK? The chinese chargers I have at the moment have had "problems" but PILA are not even quoting shipping to my postcode.:mecry:
Definitely go for the Pila IBC - better for your cells in the long run.
Moving this thread to the Batteries section.
My WF-139 terminates on my RCR123s at ~4.20V, but since it doesn't use CC followed by CV correctly, the cells drop to 4.16 within moments of the light going green. Then if you leave the cells on the charger "green" for about 8 hours, they will come back up to ~4.20V. With 17500 and 17670 cells the behavior seems to be different, It seems to CC charge up to around 4.23-4.26V give or take, at which point it goes green and the cell falls to ~4.20V (sometimes over sometimes under), then continues trickle charging them, after 8 hours I've seen it push 17670 and 17500 cells as high as 4.29V.
My gut on these things tells me that 90% or more of the WF-139 chargers shipped are probably *junk* with improper termination and overcharge problems. My gut also tells me that ~25-50% of owners will not "catch" the charger being bad necessarily, or it may behave differently with their cells and never appear to have a problem. There's a lot more to the equation of how problematic products get reported. Of course, as soon as a problem starts cropping up, and a lot of people start reporting it, owners who have not had the problem may come out to defend the purchase, beating back the problem. It's like the stock market, A bunch of people sell off, and it's almost always rebounded by a bunch of people sweeping in to buy at the newly reduced price.
I bought the 139 charger and it lasted for two charges. Ended up buying the IBC charger anyway. Go for it, I've have had very good results with mine.
Bill
Bill
Did you get a refund?
Did you buy it from AW?
Damn, why didn't I see this talk about the 139 before ordering it :mecry:
I have the WF-139 as well and I have tested the batteries hot off the charger with my DMM - for my unprotected 18650's, protected 17670 and 14500's, the light turns green when the cells hit 4.2v. If I don't happen to notice when the light turns green, the unprotected cells will usually climb to 4.23v or so.
The only one battery that seems to have an issue is my older protected AW 18650 where it consistently comes off the charger at 4.05v, even if I leave it in for another hour or so. I suspect that, due to the age of the battery, it may be nearing the end of it's life.
If I had known more about the IBC Pila charger initially, I would have purchased that charger instead.
It was going to cost me half the price I originally paid to ship it back. Needless to say I tossed it. I will not buy from that vendor again and I'm not going to mention it on an open forum. There are popular CPF vendors that will go out of their way to make things right, and if they don't I will not deal with them anymore.
Please lets not take this thread any further off topic. If you want more info PM me.
Bill
for me, i just bought a RC charger and use the WF-139(guts removed of course) as battery cradle to charge up almost any batteries....
