golden_creature
- Joined
- Oct 26, 2005
- Messages
- 101
depends where and how you carry it-i carry mine in a small rucksack pocket.gc.
The L5 is not a WeaponLight. That being said, there is no incandescently filament to damage and given that SureFire specifically intend the new KX5 bezel to replace the Z32 shock isolated incandescent bezel, I am sure it will be up to the task.ryan_kalani said:Does this light offer any type of shock isolation, making it more resistant to malfunction while mounted on a weapon?
Gordov2 said:Do you think the new Surefire L5 (with 120 lumens), at 6.1 inches long be too big for EDC? What are your thoughts???
Click here for a photo of a SureFire L5
That is correctcarrot said:A CombatLight, to my knowledge is not a WeaponLight.
I apologise if I have given this impression. There is NO reason to assume this at all.carrot said:Size15's, so Surefire's intention is to eventually discontinue the M2 shock isolation head and replace it with the KX5? I am unclear about what the Z52 model number refers to.
Those specs are for Alkaline or NiMH AAA. If one used a 10440 it is in excess of 100 lumens. That being said, it is not recommened by Fenix or me. The two main problems as I see it are it gets hot fast on high and 10440 are not protected and the chance of overdischarge is high. The light will drain a NiMH to 1.0V.Correct me if I am wrong, but isn't the maximum lumen output on the LOD-CE 50 lumens max?
From the Fenix Store Website:
"• Five output types: 20 Lumens(3.5hrs) -> 7.5 Lumens(8.5hrs) -> 50 Lumens (1hrs) ->Strobe -> SOS"
M I K said:I would think you would be much happier with a U2. Same output in a shorter light with a bezel down clip which works great for EDC carry for me.
JMHO Good Luck.
The new KX5 bezel dimensions were not available when the SureFire 2007 Catalogs had to go to press in time for SHOT Show 2007.Size15's said:The current KL5 bezel diameter is the same as the M2/K2/U2/8AX/8NX/L7 at 1.47" where as the new KX5 bezel is more like the Z32 at 1.37" so that's 2.5mm or 7% smaller in diameter.
Al
