Yes, there's a principal difference between the el-cheapo chargers just following the CC-method, and the better ones that follow the true CC-CV method.
What does this mean? Chargers only having a CC charging system, charge the battery by means of a (more or less) constant current, until a certain voltage on the batteries is reached. This voltage should be no more than 4.200V otherwise it can get dangerous, on this point numerous chargers are going wrong already.
After this voltage is reached, the chargers simply shuts off.... in the best case. Others do some kind of "trickle charge" which isn't necessary (even DANGEROUS) when it comes to Lithium-based batteries.
What's the main problem in shutting down when this certain voltage level is reached? Simple: the second part of the charging, the CV-part, simply is not carried out.
A really GOOD charger doesn't switch off when the 4.200V level is reached, it holds the voltage constant at this level for a while (hence the abbreviation CV = Constant Voltage). From the moment, the 4.200V level is reached and held constant, the current will start to fall. Ideally, the charger will shut down completely, when the current has fallen to 3% of the battery-capacity. You can see easily, that your batteries will NOT be charged to their full potential if only the CC-path is followed. You'll loose capacity.
All this is done by the charger I designed last weekend. Next week or so, I plan to build the prototype....
Timmo.
