brightnorm
- Joined
- Oct 13, 2001
- Messages
- 7,160
Do you think it would be safe to charge the 2600 and 2900 redilasts in the latest Pila charger?
Brightnorm
Brightnorm
Hard to know, since the 3100mAh haven't been tested by anyone yet, but that seems like a reasonable estimate to me. Note that true mAh capacity is dependent on discharge rate (i.e. the rated capacity is only true at relatively low discharge rates). At higher discharge rates, effective capacity drops (and the "high capacity" cells can be more affected by this than the lower ones, relatively speaking).According to your runtime chart, you got 70 minutes (1hr 10 min to 50%) on high with 2200mah batteries. I'm guessing theoretically then probably 100 minutes (1 hr 40 min to 50%) with 3100 mah? Does this sound right.
I hope so, since I've been using it on them for months.Do you think it would be safe to charge the 2600 and 2900 redilasts in the latest Pila charger?
Am I the onlyone, who did not get a holster with this light ?[/QUOTE
You're not alone. They forgot mine too.
As Summer Heat pointed out, you are reading the graphs correctly. However, I use the older lower capacity 18650s for all my runtimes, for consistency and comparison to older reviews. Newer high capacity 18650s will give you proportionately longer runtime for the same output.Am I reading the graphs right in that the only penalty for using cr123a's instead of 18650's is 10 minutes less runtime? It's not any less bright?
That's right, it seems to be very much a dealer-specific factor whether or not you get the holster. My light and holster were supplied directly by JetBeam, so that's what I had to go on at the time of the review. If it matters to you, you should make sure to confirm with the dealer before ordering.@walker sorry to hear you didn't get a holster with your BC40. Some dealers will include holsters others will not.
:welcome:The box for the BC40 I got today lists the XM-L T6 as the LED. However, the BC40 Operation Manual inside lists the XP-G R5 under specification and performance. Does anyone know what is up with the discrepancy?
I wasn't aware of that (don't have tapatalk yet, maybe on my next phone).I usually visit on my cell phone using tapatalk. I'm sure many members do. The bottom of every picture (containing the all important label of what beamshot I'm looking at) is cut off by thumbnails of other pics shown on the bottom of the screen.
Problem is the existing images are all saved JPGs, so any editing/re-posting of them would be extremely time consuming on my end. I could start doing new ones at the top, but then this will look strange in comparison to the old ones. Can anyone else confirm this issue with tapatalk?
The problem depends on the height/width of the picture, but it is easy to zoom out or move the picture to read the text.
I just got my BC40 (arrived alot earlier than expected). Anyway my new Redilast 18650 3100mah batteries aren't working. I believe there seems to be some kind of contact issue with the battery positive terminal and the spring inside the head. My AW 18650 batteries work fine in the BC40. With the Redilast batteries I am able to use the low setting. The low setting works because the head isn't completley screwed down. When I screw down the head for high output nothing happens.
