Jetbeam Jet iii-m crenulated tail bezel
PreheatedJunk
I just received a Jetbeam Jet iii-m and it included a second rubber clicker button. How do you remove the crenulated tail bezel when time comes to replace the rubber clicker?
Thanks
When I replaced the switch in mine, I took a small precision screwdriver and put it through the lanyard hole and pushed down against the opposite side of the bezel and just unscrewed it. Worked great!
Break it loose on the light and then remove the tailcap to take the pressure off the spring so parts don't go flying when you unscrew it.
Barry
