I have this driver from Kai (http://www.kaidomain.com/ProductDetails.aspx?ProductId=1845) SKU: S005025, and from what I've read here is quit uncertain what this can perform. I have to say that I'm using it with a 3xD body and a P7
From my measurements, with 3xD regular batteries I get only 0.9 A on tailcap. With 3 rechargables AA the results are the same. If the voltage drops so is the A, for example now I have only 4V on 3xD cells and the draw is only 0.5 A on high. However if I directly connect the cells to LED I'm able to squeze 1.6 A from 3 rechargeable AA.
From this thread I understand that nailbender is able to get 3 A on tailcap
I'm a litle bit confused about my results..
If this driver is a Direct drive (which I guess it is good for efficiency) why I'm not able to get 1.6 A, as much as I get for connecting the led directly to batteries? Should I assume that I have some high resistance component on path? The only thin wires that I have are the one from driver to led, those are from an ethernet cable, but they are short (5 cm?) and made from cooper.
Do you think that better batteries will bring more power or this is limited by the driver? I would be happy if I could send 1.5 A to led, since I'm using the flash in campings, where I could carry to many rechargables
Thanks
Thanks
