rizky_p
I have several KD 773 bulb to play with. not a good bulb IMO.
After playing with 6 cells i found it too yellow and dim, then i soldered 6 cells together(i was using a 3AA->2D) and add 7th cells to the pack its white and bright all right but the bulb flashed definately need soft start while using 7 cells.
I think with 6 cells Osram 64250 is alot better option, not only whiter and brighter i can get Osram 623 locally and cheaper as well . I am using Osram 64250 instead. I wish 250 can be use with 7 cells must be really bright.
Thanks to Lux for his light bulb destrutive test.
Setup:
Using KD PR to Bi-pin adapter
Did the Mag resistance mod(Tail, switch, tower, etc)
Thanks.
Setup:
Thanks.
