irjws said:Has any else notice Chevrofreak has added lithiums to his Fenix L2D rutime chart. The high mode is very impressive.
veleno said:If I use Energizer E2 lithium batteries the low and the medium levels are equal. With Duracell Plus all the levels are clearly different.
daveman said:Does any know of a cheap place to buy these AA lithiums? As far as I know, Energizer is the ONLY company that makes lithium cells in AA size, and the cheapest I can find them is radioshack, where they sell 8 for 23 bucks (~$3 per cell). Any chinese manufacturers sell them for cheap?
Vermonter73 said:I've been wondering if it could handle the high voltage of two lithiums. I assume it'll be ok with 2x14500 as well?
daveman said:Thanks, TenPin. The website claims their AA lithiums have 2900 mAh capacity, what's the capacity for cr123s?
Lobo said:Electronics aren't my strong suite, but I would highly advise you to not use two 14500. Not sure, but think the Fenix L1D and L2D (basically the same light with different bodies) are rated at 4,0V, and you would exceed that with two 14500s.
Vermonter73 said:Ah, those Energizer lithiums aren't 3.6 volts, are they? Woops.
Lithium AA cells are a different chemistry from 123 cells and I have not seen any reports of Lithium AA cells "venting with flame".Do these lithium AA cells have the same "potential" to vent & cause a sealed flashlight to explode as the CR123s?
The two types of cells have about the same energy content - 123 cells delivery about half as many ampere-hours but at about twice the voltage.Thanks, TenPin. The website claims their AA lithiums have 2900 mAh capacity, what's the capacity for cr123s?
I believe that they are entirely separate and unrelated companies.Is Battery Station and Battery Space run by the same guy?
