Anyone ever used one of these laser edge finders? Are they any good?
Does this question mean that you have a lathe? :devil:
Would need a magic staff to make things like this without a lathe and a mill… :nana:Does this question mean that you have a lathe? :devil:
Yeah, good point, but I haven't seen him mentioning his lathe.
We need pics, of course. :devil:
Lathe: Optimum D280 X 700 G
Milling machine: Optimum BF20 Vario
:poke: Now, where is yours... :thinking:
Will, since you don't use a laser to find edge, nor a mechanical finder, what do you use? I've used a wiggler on occasion, when the mechanical finder couldn't reach the edge of a large diameter part, but don't know of other edge finding methods.
You are right, I forgot about that :sigh:electronic edge finder, like the kind that lights up
I don't believe there's any fast or easy way to center the tip of a dial test indicator so that the tip (ball contact) is coaxial with spindle dead center.Or even an indicator
bring the cutter I will be using towards the edge I want to start cutting, and turn the spindle by hand until it barely touches - that is my zero.
That is a common method in Third World countries, but it isn't often done by anyone who can afford a $20 edge finder :crackup:
Even the low cost Starrett will find the edge to +/- .0005" or better. If the edge is approached slowly, it's easy to repeat .0002". Not quite as good as the really fancy stuff, but close enough for Space Shuttle parts :D
The problem with touching a sharp tool to the part edge is that the tool has to cut just a little to make the faint noise indicating contact. Maybe it cuts .0001", but that could just as easily be .0010". On top of that, if the part needs machining on more than one face, resetting the part adds additional error. The part has to be touched (cut) by exactly the same amount as it was cut the first time. To do that is next to impossible.
How about an electronic edge finder, like the kind that lights up? I never used one, do they require the spindle to spin when finding the edge? Or even an indicator but a conventional edge finder would be easier than this.
