I bread boarded my prototype for a 4 channel LED controller. The idea is to build a programmable controller box with ports to connect the LEDs which are to be installed in their own light box and cabled back to the controller box. The heart of the circuit is a 8 pin DIP PicAxe 8 bit microcontroller chip 08M that can be reprogrammed as needed. One input pin can be used as a switch to change modes or analog to digital conversion. Using MOSFETs, it will be able to control LED arrays. With a 24 volt supply, it can control 6 power LEDs in series per channel or 24 power LEDs in total at up to 700ma per channel.
The picture below shows it operating on 9 volts to power 5mm LED arrays. The layout of the LEDs are different due to the different forward voltage of the LEDs and relative brightness. I'm using the high brightness Cree 5mm 3C503B color LEDs.
I'm using the PicAxe because someone sent me a couple for free to play with. Interfaces to my computer's serial port for programming using a couple resistors and a cable that is easy to make. No expensive programming board needed.
The easy part is over, the hard part is building the little boxes for everything.
