Budman231
Re: LF3XT Programming Flowchart - V1.6 !!
1.6 Available...
Bud
1.6 Available...
Bud
Bud, you are almost there. V. 1.5 is a big improvement.
Still a couple of problems with the function setting.
1. All the function boxes: Not Used, Rechargable batter protection, etc. should NOT be colored yellow since the command here of 3C+PH does not SAVE, but rather enters you into the function that you are going to alter.
2. You need to show a 3C command with each of these function boxes that exits you out back to the ALL MODES box. Here a 3C doesn't discard what you just changed in any of the functions, but still exits you back to the mode you were adjusting.
It's there. It says Toggle Tactical Signal, under which is an arc with a 4C.I haven't read through the whole post, but can't tactical mode be used in the CUI once activated? I didn't see it on your CUI flow chart, just where you turn it on.
And if it's on there, don't mind me one bit at times -
Bud, I don't think you understood all of what I said in this post.
Under the Function setting: each of the functions (now blue boxes): 1. Not Used 2. Rechargeable Battery Protection Function 3. Mode setting Function; 4. LF3XT Reset 5. Memory Function ---All need a 3C command to exit you back to the ALL MODES. It does this without discarding the alternations you made in any of the functions (pink boxes).
In your revised diagrame you incorrectly show 3C in each of the fuctions to be altered (the pink boxes) to save the changes. This is not correct. Here it should be 3C+PH. This command will save it and will exit you back at the blue box level of the function. Again, from the blue box level you need the 3C in order to exit back to the mode you are altering. This is the only time a 3C command doesn't exit and discard at the same time. It only exits. (Another 3C+PH here would just put you back into the pink box for that function). I hope this makes sense.
Bud, the v.1.7 files are not listed or showing.
Thanks Budman231 for the AWESOME flowchart! Thanks to matrixshaman for re-writing the manual, and thanks to BabyDoc for the tips therein.
I had considered getting this light, found the manual and after looking that over I reconsidered. I found the Flowchart and changed my mind - received it two days ago! If it weren't for Budman231, I'd likely have never tried this light - so thanks again!
I would like to ask one question for clarification though: Am I correct in my understanding that if one were to toggle off the memory function the light will power up in mode 1 regardless of which mode it was in at the last power down? And only in mode 1?
Thanks folks.
Are we there yet!
Nice flowchart and very useful to me anyway.
A big thanks to making a very good light even better.:twothumbs
1.7 was the first one I actually printed...
