Budman, you are even more obsessive than I am to get this perfect, but as a doctor, I kind of like that. :twothumbs
Oh, and if I wasn't clear enough with what I already said about the factory reset, once you are in that blue function 4 box and you then issue a 3C+PH, there is no going back. The 3C command here doesn't work to disgard the results of that 3C+PH command you just issued. Again, that yellow oval area shouldn't have a 3C command in it.
(Personally I like yellow because it cautions you to be careful. There is no going back!)
OK, for the sake of this chart and CPF, I just sacrificed all of my FUI settings to test this. I issued the fatal 3C+PH command in Function 4.
What happens? When you issue the factory reset it returns you to the
CUI User defined operation mode at a 50%Max output. (This is the same way the light was when you first unpackaged it.) All the operation modes in the FUI, if you go back there with 5C+PH, are now reset to their original factory settings.
Therefore, the yellow reset oval might say: "Reset of all Factory defaults and Exit FUI to the CUI user defined operation mode (50 percent output)" or something like this.
