Fenix L0D-CE, E1, or E01 --
Simply press a Chap-Stick cap onto the bezel end.
Works great !
Although the BEST cap is from a Chap-Stick "Natural" flavor,
which can sometimes be difficult to find.
(its cap is somewhat "frosted clear", rather than a solid white)
For the Fenix L1D / L2D versions,
a clear (frosted) plastic canister from 35mm film
can be adapted quite nicely.
Cut or drill a hole, somewhat smaller than the bezel.
If you really wanna' get fancy, you can stuff clear plastic "bubble wrap" inside.
For Mini-Maglites, i
never remove the head ! :shakehead
I pop a Bayer aspirin bottle (50 or 100 size, plain ol' regular aspirin),
white plastic bottle over the bezel.
This works just like it was MADE for the job !
The only difficult part is removing the paper label,
which is glued onto the bottle VERY securely !
:hairpull: ___
___
Hint: i've found that WD-40,
applied heavily,
will slowly and gradually loosen the adhesive.
Be Patient ! Let it soak in very well !
Hey, it's not
really necessary to remove
each and every last bit of paper label,
but i happen to be quite a perfectionist. :devil:
Hope this is helpful to somebody.
_
