x2x3x2
Banned
- Joined
- Jun 6, 2003
- Messages
- 1,258
I really like the versatility of the LF (2/3/4/5) series programming UI.
It would be even better if it could be implemented with a push button.
Would you like to se the LF series with a push button?
Or should they stick to the trusty twisty?
I understand that the standard reverse clickies will not work with the LF's UI.
Probably needs a 2-stage switch which is based on amount of travel of the switch.
For example, push in 2mm for P1 and a further 2mm for P2.
What are your thoughts and suggestions?
