Hello friends
I am planing to build car taillight and I would like to use cree xp e2 red led
My first question is that in specs write that normal voltage is 2.1v at 350ma but also writes that the power rating is 3.5 watt.
That make no sense for me because with watt type w=v*i that would be about 700mw.
What I dont understand ?
Second question is that i would like to drive the led in parallel ,so if one burn do not loose the taillight ,with pwm.
In normal operation it would work in half power and when I press brake then it work on 100% of power.
Is any schematic to build my power supply?
Also I am searching for led diffuse so the led would look like simple line like audi any suggestion?
Thank you for any help
