richbuff
If you want long runtime on turbo mode, then a light with low max lumens to fuel capacity ratio is what to look for.
Thanks all for the ideas. Keep em coming! Yes, I suppose "turbo" is a misnomer, just trying to convey high output for long(er) duration.
A really well designed light should be able to do both.I'm not sure what's more important at this point - higher initial light output or longer duration of a medium level of output.
This request feels like a bit of an oxymoron. Seems like you actually want a light WITHOUT a turbo mode. It's going to be harder to find these because thermal stepdowns are cheap and easy, and being able to plaster the turbo mode numbers all over the specs are a marketing department's dream.
FWIW, I'm after a similar performance out of lights for cycling--sustained brightness for my whole ride. I have the advantage of fast-moving air to cool low-mass lights, even in summer. In terms of what lights are most efficient at getting the most high-brightness runtime out of limited W-h in each cell, I haven't found anything better than Zebralight. But, my answer might be different if I couldn't rely on moving air to cool lights. The best lights for sustained output in someone's hand or sitting on a table are likely going to be higher-mass lights with good thermal pathways to large-cooling-surface-area bodies. As the search continues for the "perfect" light, it may be important to discover each light's limitations--is it being limited by the cell (get a bigger/better/higher-current cell, or multi-cell light), or by a "turbo timer" (get a light that has a thermal sensor rather than just a time-based step-down), or the temp of the LED/driver (get a light with more mass, more surface area, better thermal pathways, a cooling fan, etc.)
