bstrickler
I have a D26-LED High Output Single Mode LED Reflector Module (3.6V-13V) from Lumens Factory I purchased from LightHound that is having a slight issue when running RCR123's.
Every 5-8 seconds, the light flickers slightly, which is slightly annoying.
I am using Trustfire 880 RCR123's, and it happens when they hit about 4.0 volts. On a fresh charge (4.05-4.10V), there is no flicker. Same with fresh Surefire CR123's.
I was wondering if this is normal, or if I might have a faulty dropin, or if the protection circuit might be kicking in. If its the protection circuit, would AW RCR123's be likely to have the same problem?
~Brian
~Brian
