Where can I buy these gems?
I will need some help: 25/50/100 lumens?!?! Which one?! I am a lumenophile/luxwhore so I long for the 100 lumens... BUT, with only 15 min runtime, I kind of think that the tradeoff is too extreme...
Where is heckboy? I really want a comparison shot of the popular keychain lights.Adding a little more detail, I've got a Drake (TiCN), Draco (Chrome), Wee NS, Raw NS, and Raw Al.
Here they are! L to R: Drake, Wee NS, Draco, Raw Al. I always forget how much I like the patina that the Wee has acquired from being EDCd.
Thank you heckboy! I had searched and searched for a comparison shot of those flashlights to no avail. Now I can finally completely compare them. Thanks! :twothumbs
I'm not really sure of the answer to that. They were different batches, probably, selected for different finishes. Also, they are all hand made, so there were variations here and there. But they all work exactly the same. For their size, they are unbelievably powerful on maximum, and you can program them to any setting you want....all three heads look a little different in size. The Ti (bare) looks the smallest. Is there a reason for that? Are they different in powers or age?
Heckboy, how many lumens did you pick for your Lummi wee?
I'm just curious--I think that as txmatt suggested, I'm going to get another pill in addition to the 100 lumen one I ordered with the light...
:duh2:
Thanks for your help! I also have the Raw NS and Wee NS on order. As soon as I receive those, the Drake or Draco will be next. Hopefully not both of them or my account will go ! lol
Thanks,
Mike
I've received my Raw NS and Wee NS. I like them both. I'm still amazed how small the Wee is...that's not to say the Raw is large, but the Wee is very tiny...the Raw is small.
In regards to the Raw, while carrying it, after the second full charge, I had it in my jeans coin pocket. When I went to use it that night, it barely glowed. I thought I had accidentally turned it on. After searching through threads on CPF, I read that the threads need to be ultra clean...lacking any excess lube or failures could occur. I wiped the excess lube off, fully charged the battery again, and haven't had any problems since....well, since last Saturday night when this happened. So, now all is great again!
I've also noticed the Wee glows slightly. It hasn't affected overall runtime (although I haven't done a true, full test). I unscrew it slightly, until there is slight battery rattle, then tighten it just a bit for the rattle to stop. Usually, that's all that's necessary.
Both lights are amazing. I read another thread about polishing the reflector on the Wee. Instead of doing this with a Dremel Tool...which I don't have the polishing accessory piece...I did this with Simichrome Polish. It changed the beam from a full flood, to a bright hotspot with good side spill. I don't have pictures, but think similar ones are posted.
BTW, the Raw NS is a 200/20 lumen model. The 200 lm is very white with a slight cool tinge to it. The 20 lm is also white with a a slight, uniform green tinge to it. The Wee NS is the 50 lumen Q3, neutral white model. This looks very similar in color to an incandescent bulb. I compared it to my Surefire E2E. Also, the Wee is significantly brighter than my CR2 Ion.
I'm considering the Wee Ti, or possibly another Limited Special...need to check funds, though.
The Drake/Draco still seem interesting, too.
Thanks,
Mike
P.S. Applevision...what are you thoughts on your new Lummis?
