Lux & throw relationship?
kosPap
Naoussa Greece
hi all! I was wondring is there an easy mathematical relationship between lux and throw?
Can I apply the inverse square law when i combine hotspot maesuremetns in order to deduct throw?
i.e. one flashlight meausers 900 lux and another 3600....can I assume that the secong will have double the throw of the first?
thanks, kostas
No, because a single throw value tells you nothing about beam divergence. You'd need at least two measurements at different distances from each flashlight to get an idea of throw.
thanks, kostas
That depends on how the lux is measured, if it is measured at some distance (like 5 meters) you can do it, but measurements at one meter is not good enough for it.
But the throw value is a very limited specification, the distribution of the light also has a very big significance.
