What you need:
1. McR17XR
2. Cree XR-E P4
3. Flupic board
4. heatsink (sanded down penny or i used a spare luxeon star HS)
replace old board with flupic
solder the -contact to the inside of the brass lip
Sand down HS and drill 2 holes for wires then AA epoxy everything down
Drop everything in(lens, reflector, module)
Notice how deep the McR17XR relfector is(15mm )
left: P1Dce max right: luxogen burst
At first i was worried about the heat generated but after thinking about it heat goes from the emitter HS to the brass can which makes contact with the lip of the battery tube and lastly to the rest of the body via the threads. hope that made sense
After using it, it ran ok and got warm pretty quick on burst but ill keep it on 600ma for now. thanks for reading.
1. McR17XR
2. Cree XR-E P4
3. Flupic board
