Does anyone have any experience/beamshots of an M2 head vs. a "C" series head? I've read that since the bulb sits further back on the M2 (which I don't even know if that is true) there is less sidespill on the M2. Any truth to that?
Please post pics.. I can't wait for my M2 to arrive..Owen said:The difference is quite noticeable. The M2 bezel kills a third or more of your sidespill. edit: I'll post a side by side beamshot with otherwise identical lights if I get a chance tonight.
Compared to the dimensions of the TurboHead reflector the 'set-back' is less significant to that of the standard bezel & M2 bezel comparison.brunt_sp said:I guess the same applies to the difference in sidespill between the KT2 and KT4 heads. As the KT4 is from the M series therefore the reflector is set back due to the shock-absorbing system so less sidespill as a result.
Okay perhaps exaggerated or obvious rather than amplified. The closer the flashlight is to the wall the more the difference between the bezels is exaggerated - the more obvious it is. In use I don't consider it to be an issue.Owen said:The difference is not "amplified" in any way. That is the beam pattern, and it does not change.
I'm going to keep it because it's black and therefore rare. I think it looks better than the Z44 so I might use it for another application.cfromc said:What are you going to do with the M2 bezel??
