Re: Machine work needed to enlarge PEU slots
While Pablo is technically correct, his advice (this one time) may lead to trouble.
"armed with a dremel, good grip, pulse and a lot of patience"
RIIIIIIIGHT
Dremels tend to slip around and grab and jump a lot when you first try to use them. A skilled person can get great results, but I'd recommend a drill press or mill with an appropriate cutter.
If you try the dremel technique, you will want to practice, a lot, before you start. The cutter you use will make a big difference, but I do not know which one would be best. You will need to hold the light steady, preferably in a vice.
If all the trit vials are not visible at the same time, then the relative sizes do not matter much and you can be fairly sloppy.
BTW, when you break the tritium vials, do so outside with the wind blowing the gas away from you. There is not much radioactivity in the vial, but inhaling it is the danger, so do not take chances.
Daniel
