I put together a Mag 2C, using 2 aw 18500 protected 1500 mah , and a Maglite 5 cell Mag-numstar Xenon bulb.
The Continuous Run Time for this lite was 1 hour 36 min. on fresh batteries.
Not as bright as the ROP 8354 Low bulb, But no heat issues and and a longer run time than the 36 minutes that I got with ROP low using the same aw 18500 batteries.
After I have discharged these batteries and recharged them a few times with the DSD charger, the voltage on them seem to peak out at 8.42 v when measured together. I have flashed a bulb or two on the fresh batteries.
My research has shown that you can let them rest for 2 hours or more and they should be fine. My findings on the other hand show this is not the case with these AW 18500 cells. At this time they have been at rest at room temperature for over 9 hours and still show 8.41v.
I can't find any "destructive" data on this 5 cell bulb or the 6 cell bulb in the charts here on the site to show the max volts you can apply and I was hoping someone may have some data on them. Output, max voltage ect.
I know I can use the same bulb in a 6 cell model instead of the 5 cell model and not worry about it instaflashing, and that I can use the krypton bulbs as well but I am looking for a solution for using this 5 cell bulb. Any suggestions or info would be great.
