Making an HID
omni96
I got this big plastic flashlight I got for about 2 bucks
It has a rather simple looking bulb
Can it be made an HID?
Which kind of bulbs should I look for?
Does it need thermal management?
(It is plastic and might melt in intense heat)
And finally...which are the best batteries for this one?
Lead-Acid, Lipo, Lion, others?
The flashlight:
I'd like to know the answer to this too, I've been wondering the same thing about a $4 6v battery plastic yellow flashlight that looks like that
Is the reflector metal or plastic? How is the bulb mounted?
I expect that if you really wanted to you could convert it to HID, but you would be better served with a different host. However, I could be wrong. :shrug:
It has a rather simple looking bulb.
If it is a standard PR lamp like in a maglite or camping lantern, then unfortunately no it can not easily be converted to hid. Common HID lamps are fitted with "H" mounts. H1, 3 and 4 are the most common from what I have found.
Anything is possible... how easily it can be converted depends on a few criteria...
Automotive H1, H3 or H4 HID lamps
Yes... sort of. The lens will need to be glass and reflector needs to be aluminum or some kind of metal. HID lamps get hot enough to melt most plastics.
Yes, the lamp will probably get hot enough to melt a plastic lens or reflector. if you leave an HID ON long enough and point it up in the sky, the little bugs and moths will attract to the light and fry from the heat off the glass. The host should be OK however.
LiPo hobby packs are the best. They can handle the current draw better than the typical SLA cells. Self discharge characteristics are better too. They are also lighter, smaller and have more wattage per unit volume. I have SLA cells in mine, but when they do die I will replace them with LiPos. LiPo packs are much more difficult, complicated and expensive to charge.
Good Luck though!!
think you going to be peeing into the wind with that host. balest wond fit,bulb wont fit and the plastic will turn to goo .
