I would be interested to know if there is any current draw when the light is off. If there is none this may be a Great thing!
Well here your update to that question. The answer is yes! If you want to know how much that will be a separate question and an extra free drop in module
Okay I am kidding. The standby current draw when its actually "Off" is 1.0 milliamp. Not surprised. However, it is similar to the SureFire tail cap technology. Meaning, it doesn't use the threads for continuity, they are hard anodized. It only uses a flat spot on the bottom inside of the tailcap to make continuity to the flat end of the case at the end of the threads, so if you turn it that minimal amount to disconnect that portion its off and open for no current draw. The switch has no momentary function.
Its on and off, then ramp up or down with separate presses, and after letting go for a least a couple seconds, the next quick on/off press/release turns it back off. I saw the current linearly ramp up and down by holding the button down. Unfornately the light response is not linear with the current to the Human eye but it does what it is supposed to do.
I used it with the Malkoff M60F that I have and the 2 17500 cells at up to 8V range with no problem. I used it with 6V primaries no problem although it seems to have less "range" of adjustment before reaching full high or low. Should I say it goes through the swing quicker. Using lower current draw LED modules also causes it to go through its swing quicker. So it works and appears to allow the Malkoff go to full brightness as the current draw through the switch as max is the same as without it at all, in this case 600mA using the 8V worth of batteries. So I am pleased.
The 2 things I don't like are the color, it should come in the same basic black as everything else, and the fact that its wider that the SureFire and Solarforce bodies by a noticeable amount. Its thicker?
On a different note I am also very happy with the diffuser I showed in previous post over any of my narrow and ringy beam Solarforce Cree pills. Smooths them out and doesn't consume a lot of their brightness. No beamshots yet, been very busy.
