Thanks for sharing your experience!
I am waiting for a M61WL and according to your description of the tint I think I will like it. But I become very surprised about one of your modules and have hard to believe anything other than it's faulty.
I have two MD2s, one with M60 and the other with M61. I would say there is NO likeness between these beams (except from both are brightest in the center)...
Also, with the precision made reflectors and the centered LEDs it SHOULD be impossible to get that much different beam profiles and especially not similar to M60!
Regards, Patric
It is hard to tell but to me the M61W has a more defined hotspot and does not seem as floody as the M61.
Brian
Beam shaping:
I think the shape of the hotspot and its taper to flood is surprisingly similar to the M60 on all 3 M61 samples, considering how large the emitter surface area is on the XPG. The angular size of the hotspot is about 60% larger than the M30W, but this is balanced by the brightness increase of 50%, so it's almost the same brightness but over a larger area, with more runtime. Win/Win!
At longer range (100+ feet) the difference in throw starts to become noticeable, but the larger area being lit is also quite apparent. I don't use these modules for ranges beyond 20 feet very often. It _is_ fun to light up reflectors and street signs a block away.
Efficiency:
There's a substantial reduction in heat output. It would be tempting to put the M61 series in a G2 or VME head.
Tint:
One of my M61 samples has a bit more red (slightly pinkish.) That one is my favorite of the 3 M61s. But I still prefer the warm white wildcat and M30W, M60WF for EDC. The richer color rendition is much more pleasing.
So, as is usually the case, the latest and greatest is not beating the older stuff on every front. But it certainly does have noticeable advantages.
Possibly but they look fine. It doesnt make sense to me either.That doesn't make sense. The die shape is the same and the reflector is the same. Is it possible that your emitter isn't positioned properly in one of the units?
--flatline
