A tad outside of the scope of this thread, however...
1)We have hail that could damage panels
Much like roofs also succumbing to hail, that's what homeowners' insurance is for.
2)Batteries are required to use solar yourself (not sell it back to the Electric company) and these batteries have a lifespan that reqiures you to replace them which can drive down savings.
3)Cloudy days hamper solar production which we have a lot of here.
The economics in my region
(and likely yours as well) dictate a grid-tie system designed around bill reduction. As such solar is best treated as a producing asset that
averages X kWh per week in a given season. Ideally, the inverter is on the panel side of the meter, production 'makes the meter spin backwards', the system is sized for peak loads during the season of lowest demand, thus you're not counting on a check from the utility generated via
mystery meat accounting and substituting a consistent slice of your electrical bill for payments on the array until it's paid off.
Adding a battery bank is a great way to double or more the cost of the system and introduce additional maintenance expenses. The main place a battery bank makes much sense is truly offgrid or in a situation where commercial power is extremely unreliable and routinely running a generator is more expensive than maintenance on a battery bank.
4)No state subsidy on Solar here, many who invest in solar do so because they are essentially "paid" (subsidized) either by the electric company (selling power at high rates) or a tax incentive which helps to pay for solar setups more quickly than having to use them for 10-15 years to break even.
The federal subsidy has been a thing for some time. All utilities are required to accept and compensate backfeed from distributed generation systems that meet minimum safety standards; the compensation they offer can range from compensation for each kWH at retail rates (net metering) priced at what they're worth at the moment (Time-Of-Use or TOU) to refunding some fraction of the wholesale value of the electricity less byzantine accounting fees. I'm not personally aware of anything more advantageous to the typical homeowner-level solar array than net metering + TOU, but I've mostly looked at the laws in CA
(because there's an abundance of literature on them), and TX which does not much incentivize installations.
Payback times using with a bill reduction logic is indeed >15 years every time I've crunched the numbers in my area, thus I've not pursued the matter in spite of miraculous claims by local installation firms.
I didn't realize how often or how long refrigerators need to be run to maintain temperatures, and I don't know the same for heating systems. This was a little bit of an eye opener for me.
Most of my extension cords are 12 gauge. I have 2 or 3 100' and a few 50' ones. I'm aware of voltage drop, and have only one 14 gauge 100' cord, that I use for Christmas lights, or the leaf blower.
If I am powering my neighbors, I'll strap the gennie to a hand truck and wheel it back and forth between the houses.
I think that 10 gauge cords have twist lock connectors, so I would need an adapter to plug a refrigerator into it.
LOL... I'm starting to think that maybe, they should just get their own generator set.
My thinking for powering the
immediate neighbor is an extension cord that has a low-amperage breaker
(10A or less) on a box near the plug on my end with no more than 50' going over the fence to their place so they won't pull enough to overload my genset running a big space heater or window unit.
