turbodog
Completed the 3-step break-in without anything terribly exciting happening. At the tail end of the run I determined experimentally that a single unit will not reliably start a small crappy window unit AC that I've got - overloaded the first attempt on both units, but curiously started the second time (post-reset) without complaint. Does pointedly illustrate the real limits of starting a major inductive load with that 2kW starting limit.
Need to contact an electrician and determine what they can do about an inlet interlock/transfer switch, and how much work I can do on my own.
I have had same problem starting an a/c with eu2k. Trick is to start using both units together, then turn thermostat all the way down and shutdown one unit. But, you are probably close to max load at that point so be careful.
