Phased_Array
As an alternative to the +$650 Li-Ion batteries from Peak Beam, I built these up. Very compact and low profile, no run times with these yet(1/2hr to 1hr maybe?).
One battery pack uses a Maxa Beam replacement NiCd 'battery housing' cut down to the battery pack cell diameter. The other is the aluminum fixed mount for the Maxa Beam cut down to the battery pack cell diameter. Both from Peak Beam.
Here is the $50 Li-Ion cell pack from Batteryspace LiFePO4 18650 Battery: 12.8V 2400 mAh ( 4S2P Side by Side, 14A rate ). And the $9 batt level LED from 'Tower Hobbies'. The connectors are a few dollars a piece from Newark Electronics.
This is the aluminum fixed base from Peak Beam(about$50).
This is the cut down plastic OEM housing.
And an end view of the battery level LED from 'Tower Hobbies' about $10
This is the cut down aluminum fixed base OEM mount.
And the end view with the LED battery level indicator.
