Maxpedition M-2 waistpack
scubasteve1942
Florida
Does anyone use a Maxpedition M-2 waistpack? If so, is it comfortable to wear on your belt all day and when sitting in a car?
I have a couple of M2 packs. They are well built. I keep one attached to the outside of a Condor 2 backpack and sometimes wear the second on my belt.
The M2 sticks out further when worn on the waist than my other, smaller holsters (e.g., a multitool or flashlight holster). Unless I am paying attention, I sometimes hit the M2 on the arm of a chair when I sit down. It is comfortable when driving -- no problem there.
The only other time I can see an M2 being uncomfortable when worn on a belt is if you load it up with too many heavy items or if you wear a long, tight coat.
Its a palm Tx. I ended up going with the M-1 instead because it was a little bigger. I just hope its not to big to wear comfortably on my belt. It should be here tomarrow. I will try to get some pics of it full with all my stuff and while on my belt. :)
