I saw your other post about using different types of batteries. You indicated you were aware it is never a good idea. Either get the other CTA or 2 more Radio Shacks. Nuff said on that subject.
I have the exact same 4Sevens heatsink. Imagine a 10 watt light bulb. OK so that's not very big for a light bulb. And now imagine it in a sealed metal box that has no air holes for ventilation. What's going to happen if you grab a hold of this metal box? It was hard for me to imagine LED's as generating heat. But 10 watts is 10 watts. You would be surprised how much heat the thing can generate. Since it is theoretically possible to generate[FONT=Arial, Helvetica, sans-serif][SIZE=-1]
683.002[/SIZE][/FONT]
lumens from 1 watt of energy. Kind of like absolute zero for LED's. And since SSC claims the P7 generates 90 lumens per watt. That means the P7 is only 13.2% efficient. Which is way better than an ordinary incandescent light bulb that is only 2% efficient. But another way of looking at that is 8.7 watts of the P7's ≈ 10 watt input is wasted as pure heat.
If you only want to spend 10 or 15 dollars on a regulator, that pretty much leaves you with the Chinese guys (DX & KD). Did you search their sites? Here's a very instructive link with a good
example of DX driver. Notice how he potted the boards right inside the DHS heatsink with
thermal epoxy. The Litemania heatsink you bought from 4Sevens is very similar. StefanFS points to a NetKidz link where he got the idea. The
3rd post from NetKidz shows hooking 2 of the 1,400 ma boards in parallel for 2.8 amps. So that's another way to do it.
The good news is the 5 mode regulator only costs $3.19. The bad news is the 1,400 ma slave only comes at a minimum in packs of 10 for $17.83. So if you're building 10 MagLites, they are only $1.78 each. The worse news is they are always on back order. Perhaps you can find one on the B/S/T forums. Or maybe you can post a want to buy over there. There must be more than 1 person that bought 20 of these things thinking they'd use them eventually.
KD sells a
pre-made version of a the NetKidz paired 1,400 AMC7135 boards for 2.8 amps output. At $5.99 this is easily the cheapest P7 regulator available. KD has had a lot of complaints lately. They are not the best on customer service. The good thing is you are only risking 6 bucks if you want to look at it that way.
Another way to look at it is for a few dollars more than buying 10 1,400 ma boards you can get a really
good regulator that won't take a month to ship from China.
TaskLED also sells the d2Flex many people have successfully used with the P7. The d2Flex isn't really a regulator but a pwm dimmer. As it pulses on and off at a few hundred times a second, it's drawing the full 3 amps. Or whatever your P7 draws in direct drive. Since it's not a full duty cycle, heat build up and a possible thermal runaway doesn't become an issue. Unless you run it at full power all the time. It also requires a
modification to the MagLite's switch so it can always have power to remember what mode the user interface was in.
