Don - Is that the 45mm clip in your pic?This thread seeks some examples so I will add a recent one of my own. I sent some Ti clips and split rings to Cetacea for installation in some web coil tethers I wanted.
Great pics folks . . . Thanks for sharing and keep em' coming! :twothumbs
If you attach them to the right-size ring, it is impossible for them to detach themselves by accident. If the ring is too small or thin, such as a regular keyring, then they can come unclipped as you say, but with a thicker ga. ring in a set-up like mine (pictured here) this is not possible. Those are 35mm clips, btw, and the ring is a Ti one I found at Berkeley Point.... these things work themselves loose too often I'm afraid.
Just curious, what are differences between the McGizmo clips & the Berkley clips or are they the same? They both say "MM" on them?
